MessagePosté le: Mercredi 03 Février 2010 08:49 Répondre en citantRevenir en haut de page
Chez Regal, il en vends un.
http://www.regal-shop.co.uk/cgi-bin/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2eregal%2dshop%2eco%2euk%2fcgi%2dbin%2fss000001%2epl%3fTB%3dA%26GB%3d%26SS%3dthrottle%26PR%3d%2d1%26PG%3d%26REFPAGE%3dhttp%253a%252f%252fwww%252eregal%252dshop%252eco%252euk%252f%26PN%3d1&WD=throttle&PN=copy_of_Cavalier_External_Engine_Upgrades%2ehtml%23a5673#a5673
Citation:
Enlarged Throttle Body - C20LET
Cavalier englarged throttle body, incorparates a larger butterfly which is attatched to a new low profile spindle providing 21.5% increase in throttle body area
Note : Sold on an exchange basis only
Price: £245.21 (Including VAT at 17.5%)
MessagePosté le: Mercredi 03 Février 2010 08:54 Répondre en citantRevenir en haut de page
Chez Courtenay
http://www.courtenaysport.co.uk/index.php?act=viewDoc&docId=6
Citation:
To a large extent, the power and torque out put on any engine is dependent on the volume of air its capable of drawing in. Research shows that the standard GM throttle bodies fitted to most Vauxhall engines are undersized and act as a bottle-neck to the inlet charge, pegging back power and torque. To over come this we dismantle the throttle body and use a CNC lathe to enlarge the diameter of the unit, as well as installing a new, bigger throttle disc and low profile spindle to suit. Typically, this results in an increase in full throttle cross sectional area of between 10 and 20%. The result? Improved torque and power outputs usually in the order of 4 to 7 bhp, as well as superior throttle response and a sharper feel to the engine. All throttle body reworking is carried out on an exchange basis.
Corsa 1.4, 1.6
Astra 2.0 8V, 2.0 16v (XE & XEV)
Cavalier, Calibra 2.0 16v inc Turbo (XE & LET)
Cavalier, Calibra 2.5 V6
Vectra V6 2.5
Astra, Vectra, VX220 - 2.2 16v - Under Development
All the above .... £255 on exchange
Omega 2.5 & 3.0 Twin butterfly .... £345 on exchange
MessagePosté le: Mercredi 03 Février 2010 23:08 Répondre en citantRevenir en haut de page
j'ai ouvert mon pap' ce soir, et pas de bride sur le miens!
j'en ai profiter pour casser 2-3 angles et rebords.
j'ai trouver une photo sur le net :
MessagePosté le: Jeudi 04 Février 2010 08:39 Répondre en citantRevenir en haut de page
je vais faire un tour a la casse voir s'ils ont des vielles zopel en 3L
MessagePosté le: Jeudi 04 Février 2010 12:12 Répondre en citantRevenir en haut de page
au fait a quoi sert le petit volet?y a que sur le C20xe et le LET que j'ai vu ca.
MessagePosté le: Jeudi 04 Février 2010 12:14 Répondre en citantRevenir en haut de page
Tu le trouve aussi sur d'autre moteur pas que des Opel, c'est pour avoir une accélération plus progressive.
MessagePosté le: Jeudi 04 Février 2010 15:54 Répondre en citantRevenir en haut de page
ok,merci isma.
donc si je toruve un papillon plus gros sans ce petit volet ca ira aussi donc.
J'ai fait un tour dans les casses ce matin,et aucune n'a de vehicules avec un V6 dedans.ca doit etre assez rare a trouver.
reste plus qu'ebay.
MessagePosté le: Jeudi 04 Février 2010 22:59 Répondre en citantRevenir en haut de page
T'as pas compris, c'est juste le clapet du boitier qui est à réccupèrer, le boitier d'origine est conservé, il est juste réusiné.
Le clapet dont on parle est un modèle de C30SE donc c'est un 6 en ligne et non un V6, mais le but est juste de trouver un clapet plus gros
MessagePosté le: Vendredi 05 Février 2010 07:40 Répondre en citantRevenir en haut de page
a ok,je pensais qu'il fallait adapter un autre boitier.
Pour l'usinage,ca doit etre super precis;un usineur "classique serait apte a faire ca?
MessagePosté le: Vendredi 05 Février 2010 19:18 Répondre en citantRevenir en haut de page
oui il serai apte!
c'est pas au micron, non plus, qu'il faut l'usiné!
il fait faire attention, car en position "repos" il doit etre un poil incliné de 1/2° et ainsi reposer dans le corps et etre étanche. Tu peux regarder avec une lumiere par derrière dans le noir, et aucune lumiere doit apparaitre sur le tour du papillon.
MessagePosté le: Vendredi 05 Février 2010 20:33 Répondre en citantRevenir en haut de page
ok,mais vu que c'est etanche,c'est le trou qui est ovalisé ou c'est le clapet?Si les 2 etaient parfaitement rond ca ne pourrai pas etre etanche.
Si c'est le trou qui est ovalisé,pour usiner cela ca doit etre chaud.
MessagePosté le: Vendredi 05 Février 2010 21:39 Répondre en citantRevenir en haut de page
mais non!!
c'est le clapet qui est ovale, sinon il se bloquerait pas dans un trou ovale!
car s'il se bloque en diagonale, il faut alors qu'il soit "plus long" que le diametre du trou.
MessagePosté le: Samedi 06 Février 2010 08:47 Répondre en citantRevenir en haut de page
merci barthus,j'avais bien compris qu'il fallais qu'un des 2 soit oval,mais je savais pas si c'etait le trou ou le clapet.
si c'est le clapet,effectivement l'usinage sera pas difficile a realiser.
Reste a trouver un gros clapet et un usineur.
Pour le clapet,vu que c'est difficile de trouver un 6 cyl en casse,je vais voir du coté des gros diesels si les clapets peuvent aller aussi ou non (genre BMW 525d,y en a a la casse).
Je vous tiens au jus si je toruve quelque chose.
MessagePosté le: Samedi 06 Février 2010 11:58 Répondre en citantRevenir en haut de page
j avais pensé a cette modif je pensé en faire débiter un au lazer un bout d'alu en 2,5 mm aucun soucis précis et une lé gère bavure petit coup de papier a ponçer et c est fini Very Happy
juste l usinage du corps, trouver un bon usineur...
MessagePosté le: Samedi 06 Février 2010 14:02 Répondre en citantRevenir en haut de page
MAT.57 > un usineur peut te faire un clapet sur mesure! c'est bidon de découpé un ovale avec 2 trous sur une commande numérique!
MessagePosté le: Samedi 06 Février 2010 20:02 Répondre en citantRevenir en haut de page
quand ça te coute rien, et que tu peux avoir un truc nickel plutot que limé pendant une aprés midi je trouve ça top mais chaqu un son point de vue
MessagePosté le: Dimanche 07 Février 2010 08:39 Répondre en citantRevenir en haut de page
Si tu tappe dans les diesel, tu risque de chercher les boitiers papillon tres longtemps... Rolling EyesRolling EyesRolling EyesRolling Eyes
MessagePosté le: Dimanche 07 Février 2010 19:16 Répondre en citantRevenir en haut de page
pk,y a pas de clapet sur les diesel???j'ai jamais touché de diesel donc je ne connais pas du tout.
je me sens tout con la Very Happy
MessagePosté le: Dimanche 07 Février 2010 19:18 Répondre en citantRevenir en haut de page
Oui y'a pas de boitier papillon, le cable c'accélérateur commande uniquement la pompe, c'est aussi pour celà qu'une dump valve ne sert strictement à rien sur un TD
MessagePosté le: Dimanche 07 Février 2010 20:02 Répondre en citantRevenir en haut de page
a ok,ben merci pour ces precisions.
J'ai vraiment l'air con lol.
En meme temps les mazout,c'est un peu tabou chez moi Wink
Damphousse
MessagePosté le: Dimanche 07 Février 2010 21:10 Répondre en citantRevenir en haut de page
mdr!!! j'avoue t vraiment con cette fois Laughing Laughing Laughing Laughing
mais bon on pe pas tout savoir dans la vie Arrow
vectra turbo 4x4 éthanol !!!!
