vectra turbine
MessagePosté le: Mercredi 24 Septembre 2008 09:04 Répondre en citantRevenir en haut de page
voila je voudrai mettre des freins a disques a l arriere de ma kadett et je voulai savoir si quelqu un pouvait me renseigner sur les modifs a faire
PS:c est une city de 78
MessagePosté le: Mercredi 24 Septembre 2008 14:44 Répondre en citantRevenir en haut de page
Slt,tu dois te procuré/fabriquer une platine support pour les étriers(étriers Audi,Golf,bmw au choix)
Pour les disques,bmw E30 (série 3 318is-325i) ou Golf 2
2 câbles d'embrayage pour le frein à main.
Quelques photos:
Si non,voilà un "mode d'emploi" de fabrication (en anglais,désolé) avec des pièces Opel et Audi:
Ascona / Manta B rear disc brake conversion
One possible solution is to use following parts:
• Audi 80 calipers, similar items are found also from other middle-size VAG-products. Those have mechanism for mechanical handbrake without special drums = good.
• Vectra A 2.0 discs
• Rekord E 2.2i handbrake cable
• Specially machined mounting plates
Project started from buying suitable parts. I did it again from my turbodude mates at Virtanen Racing team who thought these parts to be too amateur style.
Next phase is to make a modes of suitable mounting plate by measuring and modeling. If some one wants to get rid of this phase, I have 2 pairs of plates for sale... Anyway, plates has to be 8-10mm steel and include 2 10mm holes located with right distance to each others.
When plates are ready, then starts welding which has to be done properly. Big MIG does the work, but welder has to have neccessary skills. I don't... Plates will be welded just on axle bearing surface, so intall driveshafts which have bad bearings... Also calipers and discs has to be mounted tightly to plates and driveshafts before welding starts.
Then, cut original drum backplates to suitable form that you can install them like "spacers or seals" for driveshafts. I cut them to rectangle shape.
Mount discs and calipers finally and install handbrake cable... here you have discs at rear.
Si ça peux t'aider,j'ai encore des photos!
vectra turbine
MessagePosté le: Jeudi 25 Septembre 2008 14:20 Répondre en citantRevenir en haut de page
Merci de tes renseignements.Je veux bien d autres photos.
MessagePosté le: Dimanche 28 Septembre 2008 20:33 Répondre en citantRevenir en haut de page
Ok en voilà d'autres:
Etriers d'Alfa 75 et disques bmw
vectra turbine
MessagePosté le: Jeudi 09 Octobre 2008 17:51 Revenir en haut de page
je te remercie
