5chaap2k
Jeudi 23 Novembre 2006 20:26 |
My corsa at the moment:
Specs:
Corsa-B GSi (original 1.6 16v gsi) 1997
- KW coilovers
- Brock B2 Supercup 15"
- Toyo proxes t1r
- Astra-GSI brakes
- lightweight treatment
- C20XE conversion
- Chassis strengthenned
- F20 Gearbox
- Custombuilt Group-A exhaustline 63,5 mm
- Group-A Sports-katalyst 62 mm
- some body mods (grille mirros etc)
use:
- 1/4mile
- trackdays
- home/work/pleasure
some pictures of the buildup/original engine:
engine as i purchased it:
chassis strengthening
motorcrane
engine out of donorcar
engine-bay ready
engine ready
engine going in (its like lego.. )
driveshafts
byebye rotten donorcar!
hello new engine!
FAN-bracket modified to fit
more bits and bobs
first resulting pictures
new strutbrace
first event with new engine in
2lt16v calipers (mine came from a Astra GSI 16v)
Ferodo DS2500 padd's
Sandtler Serie-S brakediscs (no fancy stuff like holes or grooves)
Goodridge teflon steel-braided brakelines
New original GM (opel/vaux) parts
- bleedvalve's
- nutt's and bolts
- caliper revision kit's
Dismantled the calipers completely and got them sanded and powdercoated
then:
Cleaning brake cylinders
Goodridge braided teflon brakelines and alot of new stuff from opel/vaux note the made in britain sticker
Nice trick to get the new rubber in place without trouble
1 caliper finished
After putting together.. new nutt's bolt's brakelines' bleedbolt's etc..
Ingredients:
Sandtler serie-S brakediscs (no more drilled shit)
Goodridge teflon braided brakelines (also for rear)
ferodo ds2500 brakepets
Calibra 2.0 16v brake calipers, sanded, coated, fully revised
Movies
First testdrive:
Click here to see Video
first 1/8mile runs:
picture in picture test @ tracks (recreational lap btw)
first 1/4mile runs:
Exhaustnoise fullthrottle:
_________________ Corsa-B 2.0 16V |
mc fly#107
Jeudi 23 Novembre 2006 20:30 |
exellent job good car
Jeudi 23 Novembre 2006 20:42 |
You have a very nice car ! and you made a nice job on it !
I really like the German Style and the quality of finition in you're engine bay
The XE engine was already in a CorsaB ? The donor car had some problem ?
You have used a transplantation kit or you have made you're one transplantation kit ?
E277
Jeudi 23 Novembre 2006 20:52 |
You have a great car and I like the job you did on it
I like you kept it original style
geoffrey
Jeudi 23 Novembre 2006 21:02 |
good job
marS
Jeudi 23 Novembre 2006 22:56 |
Your car is a success and it is supers to realize well
Actuellement en VW |
5chaap2k
Jeudi 23 Novembre 2006 23:37 |
| L3gion a écrit: | You have a very nice car ! and you made a nice job on it !
You have used a transplantation kit or you have made you're one transplantation kit ? |
the donor car was rotten and could not be fixed (well could be but cheaper to buy a new one.. the engine was recently taken apart for a checkup and recondition job so it was a mustbuy
i used the transplant kit from the donorcar but not the driveshafts.. i used an alternate cv-joint to be able to keep my original (newer) driveshafts
i used cv joint's from a kadett-e 1.6 diesel with f16 gearbox
la-sentenza
Voiture: Tigra X16XE
Vendredi 24 Novembre 2006 01:43 |
Great car it works good
Vendredi 24 Novembre 2006 03:14 |
bon moi en francais
elle est vraiment sympas cette corsa simple et discrete
dohc93
Invité
Vendredi 24 Novembre 2006 15:31 |
or is what you has to buy your bar anti bringing together?
5chaap2k
Vendredi 24 Novembre 2006 17:38 |
| dohc93 a écrit: | | or is what you has to buy your bar anti bringing together? |
im sorry cant make sence of this..
ganjarom
Voiture: Tigra GSI16V
Dimanche 26 Novembre 2006 12:14 |
| 5chaap2k a écrit: | | L3gion a écrit: | You have a very nice car ! and you made a nice job on it !
i used cv joint's from a kadett-e 1.6 diesel with f16 gearbox |
si j'ai bien compris, il a pris des cardans de kadett F16?
la-sentenza
Dimanche 26 Novembre 2006 14:46 |
Je sais pas ce que c'est cv mais c'est pour monter un boite F16 ca t'arrange?
Dimanche 26 Novembre 2006 16:29 |
CV-joint = cardan
drive shaft = arbre de transmission
Il a mis des cardans côté boîte de kadett 1.6D sur ses arbres de transmission de corsa B
5chaap2k
Lundi 27 Novembre 2006 00:16 |
| nyabinghi a écrit: | CV-joint = cardan
Il a mis des cardans côté boîte de kadett 1.6D sur ses arbres de transmission de corsa B |
cv-joints:
drive shafts:
gearbox = the transmission thing
also see the nova guide for information on the CV joints:
http://www.corsa-novatuning.nl/uk/PartsA.htm
mc fly#107
Lundi 27 Novembre 2006 00:18 |
thx
