Dimanche 26 Janvier 2014 18:08 |
Surtout pas de mise à jour sur un OPCOM non officiel sinon il est mort...
calib62
Voiture: calibra c20xe
Dimanche 26 Janvier 2014 19:41 |
tu l as tester momo
momo2ls
Dimanche 26 Janvier 2014 19:46 |
Non mais je l'ai installé.
Au premier abord, l'interface n'a pas changé.
calib62
Dimanche 26 Janvier 2014 19:50 |
ok tu pourras faire un retour ?
momo2ls
Dimanche 26 Janvier 2014 20:12 |
Si je fais un essai, sans problème.
Mais le lien explique bien les mises à jour.
momo2ls
Dimanche 26 Janvier 2014 20:14 |
O
P
COM
Relea
s
e
12
0
209b
Wh
a
t
s
n
ew
New firmware version,
for the interface:
V01.45
Among other changes, t
he new firmware supports the old protocols, like KW9141-2 even
better. (For example: 25DT / X25DT, C20NE, C20LET, C 25 XE, etc.)
Many small changes / correction in the program.
Astra-H, Zafira-B AFL, AHL code index list updated
Identification of automatic transmission made automatically, the program now select the
appropriate data for the control unit, regardless of your selection,
on these models:
Astra-H, Zafira-B, Vectra-C, Corsa-D
Trouble code list updated on the following units:
Most of the control units in the Antara
Corsa-D A12XER, A13DTE, Z13DTE engine code
Zafira-B AHL
All EDC16 based Engine Control units (Z17DTH, Z17DTL, Z19DT, Z19DTH, Z19DTL) for
Vectra-C, Astra-H, Zafira-B
Meriva-B ATM
Meriva-B BCM
Meriva-B EBCM
Meriva-B A14NEL, A17DTS
Meriva-B EPB
Meriva-B EPS
Meriva-B HVAC
Meriva-B HVSM_F
Meriva-B IPC
Meriva-B SAS
Meriva-B TIM
Meriva-B UPA
Meriva-B VPS (Variable Power Steering)
Vectra-C CDC
Astra-H CDC
Zafira-B CDC
Insignia SADS
Insignia IMU
Insignia RADIO
Astra-J ATM
Astra-J BCM
Astra-J EBCM
Astra-J A14NEL, A14NET, A14XEL, A17DTJ, A20DTH, A20DTJ, A20DTR engine code
Astra-J EPB
Astra-J EPS
Astra-J FSCM
Astra-J HCM
Astra-J HBSM
Astra-J HVAC
Astra-J HVSM_F
Astra-J IMU
Astra-J IPC
Astra-J MSM
Astra-J PAS
Astra-J RADIO
Astra-J SDM
Astra-J UPA
Insignia, Astra-J IMU:
Programming options updates for the Trailer Module (TIM module) on Insignia, Astra-J,
Meriva-B.
Now all available units are supported!
Modified / updated Service Interval reset for the Corsa-D IPC! (Z13DTJ engine oil life
reset!)
Modified / updated variant coding for the Corsa-D BCM units.
Modified / updated variant coding for the Vectra-C BCM units.
Modified / updated variant coding for the Astra-H REC units.
Modified / updated variant coding / Code Index programming for the Vectra-C EHPS units.
Modified / updated variant coding / Code Index programming for the CD70 / DVD90 EHU
units.
Modified / updated variant coding for the Insignia / Astra-J IPC units.
Added Measuring blocks, and output tests for the following units:
Astra-H CDC
Zafira-B CDC
Insignia SADS
Astra-H TPMS
Vectra-C TPMS
Added trouble codes, and measuring blocks for the Corsa-B GSI C16XE
Added trouble codes, and measuring blocks for the Tecshift MTA Vivaro, and Movano
Added trouble codes, and measuring blocks for the M9R 980 Vivaro Engine, EDC16CP33
Added trouble codes, and measuring blocks for the G9U 630 Movano Engine, EDC16C36
Added
trouble codes, and measuring blocks, output tests,
programming for the Vectra-C AHS
Added support for the Power Window End Position learning procedure in the Tigra-B
Hardtop
Added
programming for the Insignia HCM
Added support for the Trouble codes, measuring blocks, output tests for the Meriva-B
ABS/ESP unit.
Added support for the Trouble codes, measuring blocks, output tests for the Meriva-B EPS
unit.
Added support for the Trouble codes, measuring blocks, output tests for the Meriva-B UPA
unit.
HVSM_F unit.
Dimanche 26 Janvier 2014 21:05 |
Je répète mais ne faites pas cette mise à jour si vous êtes sur une copie eBay...
chichi
Dimanche 26 Janvier 2014 23:07 |
Sur un forum, il y a quelqu'un qui a reprogrammé un nouveau boitier ECU sur une corsa B 1.2 en faisant la même manip que pour reprogrammer les clés .
Dimanche 26 Janvier 2014 23:10 |
J'ai déjà tenter d'enregistrer le fichier d'origine qui fait 1024k mais j'ai toujours eu peur de tenter quoique ce soit...
Mardi 15 Avril 2014 06:10 |
MP
spacetito
Mardi 15 Avril 2014 23:14 |
| LeKiffeur a écrit: | | Je répète mais ne faites pas cette mise à jour si vous êtes sur une copie eBay... |
Si le boitier est récupérable, sans souci je l'ai planté 3 fois, a chaque fois j'ai pu remettre sans problème les donnée de base aprés mise a jour officielle a la maniere d'un galletto ou vagcom, bon c'est tendu la procedure et pour 20 Euros l'OP-Com je prefere en racheté un, mais pas 3 LOL
fonteneau
Lundi 19 Mai 2014 22:43 |
Bonsoir, je reviend sur ce topic car j'ai acheté un op-com 2010 et je suis sous windows 7
J'ai vu sur les pages d'avant que certaine personnes avait des pb avec les driver.
Donc pour ça ( sous windows7), au demarrage de l'ordi tappoté sur f8, une page va s'ouvrir.
Allez tout en bas de la page, il y a une ligne qui dit " desactiver les signature des pilote"
Faite entré et le pc va demarrer.
Brancher l' op-com et le tour est jouer.
Ps: existe t il un patch en francais?
_________________ Ont dit merci qui???? |
Mardi 20 Mai 2014 06:09 |
Pas de patch Fr à ma connaissance, pour la signature des pilotes je l'ai installé hier et tu peux installé même si le pilote n'est pas reconnu, d'ailleurs Windows te le propose de lui même.
fonteneau
Mardi 20 Mai 2014 09:17 |
Ok, moi il m'as pas proposer...
Du moment qu'il fonctionne....
FJY
Dimanche 29 Juin 2014 22:16 |
Il n'y a pas de raison que cela ne fonctionne pas
Lundi 30 Juin 2014 19:49 |
Question du soir bonsoir
Qui a pu dialoguer avec un calculo de c16xe
Impossible dans mon cas ...
Lundi 30 Juin 2014 19:51 |
Tu as rentré le code à quatre chiffres pour le déverrouiller avant ?
